Re: 2 blade prop
Hi again hw, The manufacturer lists a full throttle range of 4500-5500. With my present prop I'm at 5700 (full load, by my self) and 26 MPH max speed (on my Lowrance speedometer). The gear ratio is 2:1 (26/13).I checked - out your other post (very informative),and if I did the math right, I'm at .26%.I think thats probably good. My anti-vent plate is 1" above my bottom. Since my last post, I did buy that 10 1/4 x 14p SS prop because when I ran the boat by my self, the motor went over max RPM's by a couple hundred RPM's. Besides I couldn't pass up the deal. It is a new-the-box Vengence for $125.Tell me what you think. Thanks again for your response.
