2 Batteries, how to hook up ?
osark
I have not had my 24ft Bayliner in the water for over 4 years. I just retired and I an getting it back in soon. I will be using 2 batteries, cable is #2 Welding cable. Do I hook up + to + or ?<br /><br />Thank you anyone, I feel a bit stupid. I guess I could use my age as an excuse.<br /><br />Harry
B_Eager
Re: 2 Batteries, how to hook up ?
Do you have a battery flip switch?? IE battery 1, battery 2. Are you hooking up a trolling rig??. + to + will give you higher cranking amps and 12 volts, (Just use a larger battery) or + to - will give you 24 volts but lower amps.
osark
Wave Hopper, I have I guess it is an isolater switch, you know battery 1 / battery 2/ off.<br />As the batteries will be beside each other I have a short cable 16" would I join the + to + on the batteries?<br /><br />Thank you<br /><br />Harry
Boatist
Osark<br />I you have a battery switch, 1/2/both/off then wire both batteries neg- wires to the engine block. The plus+ wire from battery 1 goes to the battery switch bat 1, the plus+ wire from battery 2 goes to terminal 2 on the switch. The output wire from switch go to hot wire for starter.<br /><br />Alternator will only charge one battery when set up this way if switch is in the one or two postion. In both postion will charge both batteries. In both postion if one battery has a problem then can discharge both batteries.<br /><br />Some switches will blow your alternator if switched with engine running, some will blow your alternator if turned turned off with the motor running. Some switches will not hurt alternator if turned or switched off, These will have a field disconect circuit and make second battery before break first battery.<br /><br />I think best way to charge both batteries is with a battery isolator.
Trent
osark
Boatist and Trent <br />Thank you for your replies. I will get back to the both of you with the results. I think the isolater switch is a Perko. I have not looked at the boat for over 4 years. I just recently moved it to a new land location and will get working on it soon. Thanks again.<br />Harry
