I just got this boat so have no prior experience with it to compare to, just what I've been told. Also, I know a lot about working on and fixing OMC outboards, but this is my first I/O so I don't know where to check for everything that could be causing this. Hoping you guys can help me out.
The boat is a 1990 Thompson Cutlass 170, 17' bowrider, with a 2.5L Mercruiser hooked to a Alpha outdrive. Only 178 hours on the motor, everything looks really good.
Took it out yesterday to try it out. Had 6 people in the boat, plus some gear. Rated for 9 people, and I don't think we were all that excessively heavily loaded. Starts up real easy. Moved along nicely at <10mph to get out into the harbor. Once I got into the harbor I dropped the throttle to go full speed and it got up to about 3100 RPM and wouldn't get on plane. From about 50% to 100% throttle, it made no change in RPM.
I had one of the passengers move up front so there were 3 in the back and 3 in the bow. That helped and it slowly was able to get on plane. Once it got on plane, the RPMs moved up pretty quickly to probably about 4200 RPM and we were cruising about 25mph. This seems remarkably slow to me for this engine and boat combo. My other boat is similar size with a 90HP and with the same load (6 people and same gear) I got 38mph and have no problems getting on plane quickly. I realize this motor weighs a bit more, but come on, that is terrible. I had a 50hp outboard on a bowrider and this was about the performance I would get with 6 people, somewhere around 25mph top speed.
Throughout the day, it was similar. I would have to beg and wait to get it up on plane, then I could get it up to about 25mph. I tried launching with the trim in all different angles to see if anything helped.
Coming back into the harbor we were fighting direct against a 20mph wind and nothing I could do could get us on plane. I was stuck at 3100 RPM and about 15mph. After about 10min of fighting it, the wind died down suddenly and it surged forward as it got on plane.
The prop is a 14.5x19. The previous owner used this same prop for years, so I don't think it is the prop. He said that it would typically max out around 45mph with his family in it, so something really seems wrong.
My first thought is old gas. He filled it up at the end of last summer, so the gas is pretty close to a year old. I burned about half during the day and refilled and it didn't seem to make much difference, but I know that when there's that much bad gas it isn't diluting very quickly. Do you guys think this is the most likely culprit? I will try to drain it all tonight and refill and see if that helps, but since I am new to I/O engines, I am wondering what other possibilities it could be to give me this problem that I'm not thinking of?
It really feels like a lack of power, like I said, it reminds me of when I had a 50hp with a heavy load of people onboard. Once it gets on plane, it accelerates more, but the top speed and RPM doesn't get to where I'd expect.
I checked the throttle cables and linkages and they all seem to be working perfectly. Any tiny change at the controls makes the throttle cable move, and the linkages on the carb. Previous owner said he replaced plugs and points 2 years ago.
Tonight after I drain the gas, I'd like to check as many things as I can, so give me some ideas on what to look at. Thanks!!!
