Specifics:
1997 140 HP Jet Drive
New to me, it idled fine on initial test but poured fuel fro the lower carb.
Removed oil injection system.
Now 50:1 mix in fuel tank.
Cleaned all carbs thoroughly, and replaced gaskets an all 3 needles, float levels verified. (this cured the pouring fuel problem).
First on the water test was Friday morning...took several tries to get it started with choke, but finally did and idle was a bit rough but ok.
WOT was 4100rpm and approx 30-35mph.
Fiddled with the linkage to make sure that the butterflies were opening all the way, and verified that the cable adjustment was allowing the linkage to reach the pre-set "stop".
Tried to fire it back up (several hours later) and it won't idle without choke, 1500 rpm sounds like it's not firing on all cylinders, smooths out at 2000-4100 with same previous speed and WOT rpm (4100) but will dies below 100 rpm.
Have fire at all 6 plugs.
Idle mixture screws were carefully re-set to original setting (10.5 turns IN).
Throttle linkage settings unmolested.
What do I try next to get it to idle?...I plan to use a home made manometer to tune the carbs, but must get it to idle on it's own first.
