2.3 ford OMC no spark
Casper1719
Hi all, new to the board. Looking for some help on this issue. All ignition parts replaced. All checked and good. Still no spark. Could it be a bad ground?? There is some sketchy wires. Thanks
Ayuh,.... Welcome Aboard,..... Is there voltage at the coil's (+) terminal with the key "On",..??
Do the points arc when you open, 'n close 'em manually,..??
