This is for the older 2 stroke engine, but there are still quite a few of them around.
I picked up a 1986 2.2 hp Mercury outboard skeleton. I was able to put it back together and got it running great. I read about modifying the carb slide to get to 3.5 hp, but my slide was opening fully. I looked for some time for a cheap 3.5 hp carburetor and finally found one on a scrap 1998. Woo-hoo. 3.5 hp here we come.
I pulled the 2.2 hp carb to compare it to the 3.5 hp. Checked 13 mm throat. Both the same (embossed 13 on the throat). Checked the jet. Both were #66 drill bit. Checked lever throw on throttle plastic plate slot. Both had 65 mm throw. I was stumped and thought that maybe the 2.2 hp was already upgraded?
Then I noticed a difference in the front carb plastic plate that holds the kill switch. The 2.2 hp plate has a complete fit to carburetor face. The 3.5 plate has a 13 mm x 12 mm cutout. The air to the 2.2 hp is limited by the face plate. The cutout on the 3.5 hp allows more air to the engine.
Whether right or wrong about this, I'm going to cut a notch out of the 2.2 hp face plate and see if it breathes better.
Any comments? vic
Any comments? vic
