Sort of inherited this little boat motor, not running of course.
Not sure what year it is, but it's a little Johnson 3hp, Model: JH 19M.
So I first checked the big 3. Air, fuel, spark.
Turned the fuel on, standard. The sticker with starting instructions also says to open the air vent? No idea what or where that is. Proceeded on anyway!
Pulled the plugs, check them for spark. Plugs looked good, spark was nice and bright. Tried to start it, nothin'.
Further investigation. The gas smelled nasty, looked terrible. Drained it, cleaned the tank. Pulled the fuel line and that was full of oil and some sort of solid substance. Pulled the carb, not a drop of gas in it, but it was clean. So, I was thinking I wasn't getting any fuel. Cleaned all the gummed up oil out of the carb. Cleaned the carb, cleaned everything..
Tried to start it today with all new fuel. Still nothing. Fuel was barely dripping out of the petcock (it was cleaned as well) and we couldn't feel any pressure or anything coming from the exhaust.
Suggestions?
How much oil should I be mixing? The sticker said 1/3 pint /gallon. So I did 155~ ml to my 1 gallon of fuel.
Should I feel compression coming out of the exhaust?
Should the fuel be steadily flowing out of the petcock/gas tube?
Shane
Suggestions?
Shane
