It's giving me fits. During duck season I had problems of it not wanting to start unless i would hold the "advance" open on the carb while starting. It wouldn't idle worth a crap. Once started it would run. I ran sea foam through it and it worked ok. two weeks ago I was running wide open and the motor stalls out. I could get it to idle on the first pull but once in gear if I tried to give it throttle it would die. Try the open carb up to start trick and it just floods it out. Pull carb and nothing anywhere in it(no junk at all clean as a whistle). I clean it anyways, install new plugs. It starts on the first pull every time but when trying to put rpms on it it dies. IT'S DRIVING ME CRAZY!
