1999 johnson 50hp j50pleea oil leak
fordwheeling250@yahoo.com
I have a oil leak coming out from the housing behind the prop.. I replaced the propeller shaft seal, and the bearing housing O-ring. What other seals in the gear case would allow oil to get into this area?
Honorary Supreme Mariner
Oil from the exhaust often leaks here.--It appears messy but is not a problem.
How long did it sit after running before you checked the oil ?----Pressure test the gearcase to look for any leak points.
