Thanks to everyone on this forum for all the help...Amazing people here. I have problems with power. 115 Johnson v4 J115Pleem Engine starts easily every time, idles rough but stable and runs fine at low throttle. Try to open up and it bogs and doesn't have the power. Started with new plugs, chased fuel filter, supply, vent and primer bulb...No help even with squeezing bulb while running. Rebuilt/cleaned all four carbs thinking clogged high speed jet, nothing. Inline spark tester showed consistent spark but light wasn't as bright or fast as compared to my generator? Noticed a bit of fuel leaking in the engine compartment. Compression showed only 35psi in all four. Took off head cover and cylinders and o ring gaskets looked fine but there was crud on the little nubbin things in between the bolt holes. Questions: would the engine run at idle and low speeds fairly well with only 35psi? Inline spark tester lights up, does that mean spark is OK under load? Do I need to worry about the cruddy rubber nubbin things on the head cover or just replace the four o ring g gaskets? Is Powerpack the next step? There is only one Powerpack, can I test it?
