1999 Evinrude 115 Ficht Oil Injection Help
hhowle
I have a 1999 Evinrude 115 Ficht motor, and I am having issues purging the air in the oil lines. I am using the Evinrude diagnostic software to trigger the oil injector, and it clicks but won't let any oil through. I have verified the oil pressure all the way up to the inlet to the injector. I have also bypassed the oil lift pump to see if it was restricting the oil flow. During the attempts to purge/prime I have triggered the oil injector while pumping the oil line bulb and restricting the oil return line. I have replaced the oil injector with a new one also. I have the specific services manual for the motor and I have followed all of the suggested steps for troubleshooting with no luck. I have also verified that all of the oil/vacuum lines are connected correctly. The motor will start and idle fine, but there is no oil flow, so I haven't ran it for more than a 10-20 seconds since rebuild. If anybody has any suggestions it would be greatly appreciated.
HT32BSX115
Howdy,
Welcome aboard!
Unfortunately, you have posted in the OMC I/O (Inboard Outboard) forum.
A Moderator should be along shortly to hook you up into the Evinrude forum!
http://forums.iboats.com/forum/engine-repair-and-maintenance/johnson-evinrude-outboards
Regards,
Rick
Faztbullet
Make sure the check valve from lift pump to injector is installed correctly and make sure pressure regulator installed with arrow toward return
