I'm an outboard motor noob and I recently came into the possession of a motor that almost, but not quite, works. It will crank it is getting fuel to the plugs, and it has good compression, but it wont start. The previous owner got new parts to all the electrical components except for the voltage regulator, but when I was looking things over, I found a hose that looks like it had broken off of the piece that it was connected to. The engine is a 1999 Johnson, 90hp outboard. The piece is at the back of the engine, near the bottom. My questions are, will a bad voltage regulator keep the engine from starting and what is the part that the hose looks like it broke off from?
