LGM30Glauncher
Thread starter- Joined
- Dec 30, 2002
- 3
I bought this motor new and this is the first time I've had any trouble with it. It's a 1999 90hp Johnson, 2-cycle. I'm getting ready to sell it and I wanted to show potential buyers that it works. I bought a pair of muffs, placed them over the water intakes, started the water flowing and started it up. It started fine, but no pee. Then I read through the "micro" manual and it said to have the motor at a good tilt. So, I tilted it as if it was on the lake, but still nothing.<br /><br />My brother said with the muffs, it should pee even without running. Is this correct?<br /><br />However, it's cold here (45 degrees). Is the T-stat not letting the water pass until it's hot enough? If so, how long should I wait (I get nervous with no pee). So far, I haven't waited long enough for any idiot lights to come on and I really don't want to.<br /><br />I've looked through a lot of these messages concerning the pee problem, and at this point all I want to do is get a good plan together of what to check, in what order.<br /><br />My list, from what I've read so far:<br /><br />1. Check for clogged intakes (I already did this, they look great).<br />2. Check for a plugged pee hole by cleaning it out with a wire (paper clip).<br />3. Check to make sure the pee hose is still hooked up.<br />4. Check the T-stat.<br />5. Check the impeller.<br />6. Just plain screwed.<br /><br />Thanks, ahead of time.
