1998 volvo penta 5.7 gs 350 chev with a holley 4 bbl
Zerroo1
asking for help....i have a holley carb right now but i want to turn it over to an edelbrock carb....what do i need to do to convert over ?
Why?
Lots of work and parts for loss of performance
There is a reason VP put a holley on the motor
Ayuh,..... Ditto,..... Alota work to switch brands of carb, with no pay-back,.....
Not that I like Holleys, but Volvo did,....
jimmbo
Again why? You will not gain any power. You may need a different intake as the Holley is probably a Spreadbore(model 4175) and the Edelbrock... Edelbrock did sell some Quadrajet carbs too, but I don't know if they were USCG certified. Most Edelbrocks are Squarebore. Unless the manifold is made for both type of patterns, then a manifold is needed. Adapters? Best thing to do with them is to toss them overboard as they DO NOT work very well.
Lou C
You will also have to change or modify both the fuel line and the throttle linkage. Seeing as how there is just as much support for the Holley vs the Edelbrock if not more why change? And as noted if the Holley is the spreadbore 4175 it is the only modern carb designed to replace the Quadrajet which is what that cast iron intake was designed for.
VP used the 4150's 4160's and 4175's over the years for 4 barrels and 2300's for two barrels with an adapter to the 4-barrel manifold
seeing the OP only has one post and hasnt been back, we would need to get the rest of the alphabet soup in the model number to be specific as to what he has and why he would want to change
motor may have the holley 2300 2-barrel and adapter and OP may want a 4-barrel. if that is the case, going to a 4-barrel would be easiest with a spread-bore to square bore adapter and a holley 4160 as the fuel line and throttle would line up.
Lou C
Yep that's what I put on my '88 OMC 4.3. 4160-4bbl calibrated for the V6 with a Mr Gasket adapter. I was able to get the OE style metal fuel line that fit perfect. I just had to fab up a bracket to properly locate the throttle cable and move one of the tilt n trim relays on the OMC Cobra shift linkage bracket so it would clear the secondary diaphragm housing on the Holley.
Zerroo1
i was just told by a few people that run edelbrocks on their boats are very happy with the out come of performance and very little adjustments that are made....for the last 5 yrs i have been cleaning out my holley because the ports and needles are always getting clogged...but this year im emptying out gas tank hoping thats the problem....and thats why i was asking for help or advice
GA_Boater
Welcome aboard.
If your Holley is clogging up, why do you think an Edlebrock will fare better?
The tank may need cleaning and adding a water separator/filter can't hurt if you don't have one.
jimmbo
Squarebore carb to spreadbore manifold adapters are something to be avoided except as a last resort. None are good, the least poor of them being the one Mercruiser made and used on GM V8, but most are terrible. Almost all squarebore 4bbls will have larger Primaires than a spreadbore carb, and much smaller Secondaries. An adapter will, on the primary side, be restricting the flow from the larger primary carb bore. This will result in differences in vacuum levels and velocities in the intake Compared to what is below the carb in the adapter. While on running Where only the primaries are open, it is similar to a carb that is too big for the engine. When the secondaries start opening, they are facing the much larger secondary holes, and will see the intake vacuum with no restriction choke down. This will cause some imbalance between primary and secondary sides and a reduced signal in the primaries, with a possible richening of the gas-air mix. The secondaries will be getting a stronger signal, that may lean it out compared to the primaires. An equalibium will establish itself but it will far from ideal, when compared to a proper carb to manifold match
Zerroo1
i just find that edelbrock is so much better at being maintained then the holley (just my opinion)....and for the clogging of the holley i think edelbrock will just do the same but less cleaning for the edelbrock
jimmbo
Holley, at least in the 4150, 4160, 4165, 4175 series, is a far easier carb to clean. The meter block lays most of the fuel circuits exposed. The passages in the carb body are pretty much straight and have easy access once the metering block is removed.
