1998 merc 150 efi problem
Dale stevens
When engine is cold it starts fine and has an ok idle. After a run it has a very rough idle and stalls out. While on plane I run normal speed and rpm . I did an ohm test on the coil ( cold) and the seemed ok. Could ther be a coil problem when they get warmed up. Thanks
gm280
Dale stevens, :welcome: aboard to iboats...
Sounds like you are getting a heating issue with the spark. One thing you can do to point to the problem is while running, once the problem seems to be going on. remove the spark plug boot from one cylinder and see it the engine's RPMs change. If so that cylinder is working. If not then you found the cylinder that is not firing and you can start testing the coil and such. One good way to see it the coil is a problem after locating a suspect one is to swap the coil with a known good one and try those tests again. It the problem follows the coil, bingo, you found you bad part and time to replace it. If the same cylinder still has problems, then the ignition system that goes to that cylinder needs checked. JMHO!
Dale stevens
Ok update. Took the boat out and ran around to get it hot . I bought a timing light and I tested it on the water. All the coils seemed to be firing. I had a steady pulse on the light on all cylinders. Could my power packs be failing? Also noticed two other symptoms 1) while it was idling I noticed a slight surge in rpm. Not a big surge 2) I seemed to be turning more rpm while running on plane. I'm not positive my gauge is correct though. After another run I was putting the boat on the trailer I seem to lose more power it was tough to keep running . A friend also suggested I check the air intake sensor. Any suggestion on that?
Dukedog
might get tha tpi, head temp sensor, air sensor checked? when cold a lotta fuel is used at idle.. warm not so much, will load up if any of these or bad..
