1998 johnson ficht 150 won't crank
smurphy1976
Engine ran fine all weekend when I turned it off on Sunday it would not crank back up. The fuel pump would run when you turn the key and all guages worked. I crossed the solenoid with a screw driver to get the starter to turn over to get me home. Today I replaced the solenoid but same problem. Any detailed suggestions would be appreciated...still pretty new to the outboard scene.
