1998 four horse johnson will not start
jasj
I have a 1998 Johnson outboard that has an internal fuel tank plus the connection in the front to attach an external fuel hose. This is all controlled by a selector knob on the front of the motor case. In the process of diagnosing why the motor will not start and reviewing all the fuel lines, it appears that the fuel pump on the side of the engine is only used when using an external fuel tank, otherwise fuel is gravity fed to the carburetor from the internal fuel tank, bypassing the fuel pump. Is this a true statement ? Engine just runs for a few seconds and quits. Carburetor has been disassembled and reassembled. Fuel in bowl, all jets and passages were clean. Good spark at plugs. Compression test around 90 lbs both cylinders. Would like to eliminate the fuel pump as a cause since I am using the internal tank on the outboard. Any ideas why it will not start would be appreciated.
noob_boater
Re: 1998 four horse johnson will not start
i have an old 4.5 sears/eska outboard that functions similiar to yours. I am currently using the built in gas tank. was having a bit of problem keeping it running until i adjusted the fuel/ratio mixed screw.
my 20HP johnson couldnt start. i checked everything like you did and all were good. turned out the motor had a sheared flywheel key. Put new one in and fired in 2 pulls.
Lenard
You need a very good cleaning of your carb!
