1998 force120
Hi all!! First post :) All i need to know is where i can find a spark plug wire kit for this motor. I've looked everywhere. All i can find are all the same length wires when the ones that are currently on them are different lengths. Does this mean i have to buy each one individually? I have recently purchased this boat for five hundred bucks because of a starter issue :lol: i just want to get everything done before i take it out. Thanks for your help.
Frank Acampora
Re: 1998 force120
All the same Length does not matter as long as the wires will reach the bottom plug from the bottom coil. The others will simply loop a bit.
jerryjerry05
Re: 1998 force120
7 or 8 mm?? Buy a 2-3 ft piece and cut it to length.
I think??? The black are 7mm grey is 8mm Not absolutly positive??
OR. The parts come as 1 wire and instructions say cut as needed. 821945A61 Mercury part#
Re: 1998 force120
Thanks so much you all were right. perfect fit.
