Rscamarochad
Thread starter- Joined
- Feb 23, 2014
- 3
Hello all:
I have a 1998 Force 75.
Just so you have a little history on the motor and me. I have previously been an auto tech. I'm fairly mechanical but not all that familiar with more complex marine issues.
When I bought this boat I redid the entire fuel system. I put a canister fuel filter, all new fuel lines, a new inline filter and rebuilt the carb.
I also did the lower unit lubricant and an entirely new water pump. I added a water pressure gauge and I have always monitored it closely as well as the tell tail. I also have a volt guage and never noticed any major fluctuations in voltage.
My current problem is that it seems to have lost power and now dies almost instantly when put into gear while in the water. The last time I took it out it ran great the whole trip and as I was headed for the ram I noticed the power drop off rapidly. I wound up having to use the trolling motor to get it on the trailer.
Ok leading up to this incident, the motor had a very minor and barely noticeable miss while cruising at moderate to WOT.
The motor was running "great" prior to the last day that I took her out and had the incident.
Frankly from what experience I have, I truly thought the motor lost compression in one or more cylinders. That's what it felt like.
Today I compression tested the motor cold. I got 120+ lbs on all 3 cylinders. So now I'm perplexed. I'm not sure what to test next? Coils? Regulator? Any help greatly appreciated.
