1998 Evinrude 115hp - SPL
Russrio
Hi,<br /><br />I'm having a weird starting problem with my Outboard, It starts first time when engine is cold, but very hard starting when engine has been running, then shut off for about 1 hour... I brought it in to repair shop, the first time they replace the Thermostats said engine running warm, and could be the cause of hard starting.. Well that was not it, I replaced the Primmer bulb also cause when It was having problems starting, I notice the bulb would not get hard or push fuel threw to engine... Well That did not fix problem either, I took it back to the shop, they said they ran it a long time and had no problems starting it...They checked the float on carbs said all was okay... I'm kinda fustrated right now, Boat runs fine once started or if engine is cold, but Have problems when engine is warm.. I can get it to start eventually by pushing key in for primer solonoid, and giving it some throttle or using starting fluid... Does anyone have any Ideas on what I can do.. Thanks
Russrio
Re: 1998 Evinrude 115hp - SPL
Does anyone have any sugestions or Ideas on what I can check for regarding this problem.. Thanks :confused:
