A.Hoj
- May 24, 2006
- 39
OK so I've been out 5 times this year with the boat. every time I get up to 4500RPM the motor bogs down, I slow down speed up and its fine for a second then it does it again and again. Last winter cleaned out the tanks wich were nasty. Then I changed the fuel pump, fuel hoses, filters, and it still does it. Today, took it for a ride and still did it after some carb adjustments. so I"m thinking why didn't it do this last year? and I realize I cleaned the tanks in the winter which had very heavily mixed oil/gas and started this season with fresh 50:1. So I add a few ounces of oil to bring the ratio to about 35:1 and guess what? It runs perfect again. Can someone explain why this motor runs great with more oil than recomended?
Thanks!
Thanks!
