1998 50HP Johnson - Electrical Problems
darkthirty
After a 3 hour fishing trip, the power T/T worked fine. Went to second location, power T/T would not lower the motor. Had to manually lower. Checked on the problem, and found there was no electrical power to the starter. Checked all relays & fuses. They're good. Battery ok, no corrosion issues. What do I check next? Are these 2 problems related?
