1998 4.3L RPM Drop
tank1949
If you can remove tank, do so and flush with fresh water. That old of a boat, it be a good idea to examine tank now for leaks. Usually, but not always, the crap will float out with water. If you can't remove tank. buy you a cheap electric fuel pump and circulate (pump) gas in tank through filter and back into tank. Acetone will suck up water and may dissolve sludge. I have a feeling that you have a lot of sludge in your tank that must be removed. A portable tank supplying uncontaminated fuel will identify if your existing gas/tank is the source of your head acks.
Johnnymc
Thanks for the information. I have syphoned all the old fuel out and replaced with good fuel. Ran the engine with a new fuel separator and separate tank with new fuel and the problem persisted. Having the carb checked and going through fuel system again the make sure I didn't miss something.
