brucetech09
- May 8, 2018
- 19
boat was idling a little low this season and would sometimes stall kicking into gear. Sooo I adjusted the idle screw in gear to just under 800rpm and I adjusted fuel mixture screw and it runs very good and starts very easy now. One problem, when in neutral it idles around 1100rpm but once in gear it drops to about 800rpm. Is there a way to adjust it so it stays around 750rpm in gear and neutral? I read it shouldn’t change. Am I risking damage as is?
