1998 150hp 2cyc efi dies when warm
Mhemry
I have been having this issue for a few years now. The motor starts and runs great when it is cold. Once I run a few miles the motor dies at idle. In order to get it to start I have to quickly put it in gear. If the motor cools off I can start it and idle no peoblem. Any help is appreciated. Thanks.
Faztbullet
Check the MAP sensor hose......lil hose from ECU to manifold fitting. They can fill with fuel and cause issues.
Mhemry
I pulled the hose off the manifold and it looks like it has some moisture on the inside. Should I just replace the hose?
