I have a 200hp yammie, counter rotation with 330hrs
I went out in the boat the 1st day it run fine. Went out the next day, and heard a clunking sound so I pull back the throttle and check the engine and look at the lower unit to see if I pick up anything and I didn't. Start back up, shift it in forward and moves fine in idle, gave it some throttle and it start jerking and clunking. It run at idle for 6 miles to the marina.
I just replace the lower unit because the same thing happened with the old 1.
I need some help, I am thinking 2 lower units can't do the same thing.
It takes forward only at idle speed but reverse I can get more speed without any problems.
HELP.
HELP.
