1997 to 2001 2 stroke mercury 90hp
wellcraft26
Does somebody knows if everything from a 1997 2 stroke merc 90hp is compatible with the same engine from a 2001?
I have a 1997 engine that I would like to swap parts to a newer 2001 engine.
Thanks
Faztbullet
Everything will swap..to make lower unit work will need to use old shift rod and linkage
wellcraft26
Awesome, so the only thing will be and I can make it work by swapping those parts to the newer one?
Thanks so much for your input, been trying to find an answer the whole day by searching.
