1997 Mercury force 120
newton1157
When I squeeze the primer bulb it does not get hard and if I keep squeezing it then it floods the carbs could that be the fuel pump ?
pnwboat
Re: 1997 Mercury force 120
If the carbs are flooding when you squeeze the primer bulb, then there is a problem with the needle valve in the carb(s). Either there is some debris stuck between the needle valve and the seat, the float level is set too high, or the rubber tip on the needle valve is bad.
t money
Not to sound like uncle money bags or anything but I had squeeze bulb issues on my 1987 and I think that it was the orginal fuel line. I was 10 mins and $25 to replace the line. While it didn't fix my problem I do fuel good knowing that I don't have to deal with that for a while.
