1997 Johnson 175 Ocean Runner wearin me out.
dkkoonce
My Dad has a 97 Johnson 175. It was stuttering hard above 2000 RPM. I read here about temp sensors causing problems so they were disconnected and it got better. Both sensors were replaced and it ran OK for a few days. Today it was back to stuttering above 2000 RPM until the sensors are disconnected. The pee stream is barely getting warm but there does seem to be a detonation sound when running higher RPM. The fuel bulb was replaced also because of a surging condition when throttled up. The temp horn has been eliminated but the engine does not seem to be over heating. Is there any connection between the sensors and the throttle assembly that may be causing problems? The right head (the one with the dual wire sensor) does seem to be hotter then the left. Any comments would be appreciated. Sorry for the novel.
hammer250v8
Re: 1997 Johnson 175 Ocean Runner wearin me out.
david...<br /> i had the same problem with my 91 250! went out on the lake and buzzer and s.l.o.w feature was enguaging. unplugged the dual wire temp sender and prolblem went away. took it to the shop to be safe and they said they couldn't find a problem. it's been two weeks since.weird problem but went awaty by it self. take it to a good dealer and have it checked out. it's probally a s.l.o.w. feature malfunction....james
