1997 force 40hp ELPT
Bubber
I have a 1997 force 40hp 2 stroke serial # OE246618 starts right up, take it out runs great at first at 5200 rpm then cuts down to about 3000 rpm. If I leave it sit for a while then start it back up runs great again. Would anyone have any suggestions on what's going on with the motor? Thanks
jerryjerry05
Welcome,
​The vent line from the tank, sounds like it's clogged or the tank vent isn't open far enough??
Built in tank?
Or portable tank.
Bubber
Yes its a built-in tank. I'm going to try to clean the vent tube tomorrow.
tommarvin
Ensign
This could be when old ignition parts get hot/overheat, you can't start the motor for around 10-15 min until they cool down and start working again.
If it's not fuel, I would start testing ignition parts. outboard ignition.com has troubleshooting and testing for all ignition parts, cdielectronics.com has the same thing too.
jerryjerry05
I never heard of parts on an outboard "getting hot" and stop working.
Usually they stop working.
Now if it was an I/O with an automotive coil, yes that might happen.
Bubber
I think it's my fuel pump. I have to keep pumping the primer bulb to fill the inline filter.
