Just bought a 97 tracker with a 40hp force on it. Have only ran it a couple times. Shame on me, the second time I ran it slap out of gas. Ever since then it hasnt run as well as it did when i first bought it. especially on cranking and recranking(have to give it a lot of throttle to keep it running till it gets into gear then itll run/idle pretty well) I did get the local shop to fix distorted fuel pump valves and clean the carburator already. Anywho, while a buddy and i were working on it we popped the top off the cowling and noticed what appeared to be water collecting in the bottom of the plastic housing that holds the top of the motor(unsure of the correct name). He said there should never be any water in there. Not sure if it was there when i bought the boat or not. So the question; should water be getting in this area of the motor or not. Its technically not the motor but just in the housing that hold the motor wires etc.
new boat owner.
new boat owner.
