1996 Mercury 150 EFI start issue
Dacrud
Hi,
I'm having trouble with this motor starting. S
tarts and runs great with just ear muffs in the driveway, but under water it won't start. Also when I turn the key a quarter turn I don't hear the normal beep anymore, only about 50% of the time, but I still hear it priming.
When I put it in the water crank it tries but won't stay running for more than 1-2 seconds. Then sometimes it struggles and just spins and spins while I hold the key. Trimming it up out of the water allows it to start.
Any tips, anything would be appreciated. Thank you
Faztbullet
Check spark as sounds like running on one bank....no back pressure and it starts easier.
Dacrud
Thanks for the information, I will do the spark test.
I did notice yesterday on one of the spark plugs when I put new ones in that the black connector end that goes into the motor, not the spark plug, was very lose and it almost pulled right out. I don't know what that end is called but it's about as big around as a quarter and has a gold piece on the inside. I just pushed it back in.
