1996 Mercury 15 HP Waterpump
otth2oskier
I replaced the impeller on my motor. I tested it in a bucket with a cordless drill driving the shaft. It pumps great, lots of flow and pressure. When I reinstalled the lower unit and tested it, there was very little flow, almost none. I am at a loss of what to try. I am quite sure I lined up the tube up to the powerhead properly. Any thoughts?
Maybe put more water in your test bucket.------Water must be 6" above the pump.
flyingscott
How long did you let it run. The thermostat controls the pee hole on that motor.
