Re: 1996 Mariner 150HP Overcharging Batt 16.5Volts
I've got a 175 Mariner, and I just experienced the same problem you're having. In my case, it was the voltage regulator going bad. Some of these engines have 16 amp charging systems, and some have 40 amp charging systems. The 16 amp has the voltage regulator located directly behind the flywheel. Small square shaped part with a red and yellow lead. It's about $140. On the 40 amp system, however, the voltage regulator/rectifier is located behind the plate that is located in between the coils. If you see any wires coming from under that plate, you probably have the 40 amp system. If not, it's the 16 amp. If it's the 40 amp system, it's expensive. That voltage regulator/rectifier is about $440. I replaced mine myself since I had the 16 amp system, but if you have the 40 amp system, you might want to let a Merc tech at least diagnos it for you. Probably don't want to run it anymore until it's fixed. It could start damaging other electrical parts. (Stator, etc.)<br /> Good luck,<br /> Kenny
