Goldfinger
- May 6, 2008
- 2
Repaired leaky carbs and hoses and installed water pump kit. Upon restart of the motor and a few adjustments to the carbs and linkage per OMC Manual the lower cylinder would not fire all the time. Coil checked good and appeared to be power pack which I replaced. Problem still occurs although not as frequent. Any suggestions, and what is the easiest way to check Stator and Trigger. When linkage, carb and timing advance settings recommended by OMC manual were set the RPM's were around 1600. The only way to decrease the RPM's was to back off the low idle screw which retards the timing, is this correct. Any help appreciated.
