18 volts output. What is wrong with my motor ? Rectifier/Regulator ? HELP !
P Pro23 Recruit Thread starter Joined Jun 14, 2001 Messages 4 Jun 22, 2001 #1 18 volts output. What is wrong with my motor ? Rectifier/Regulator ? HELP !
D Dhadley Supreme Mariner Joined Feb 4, 2001 Messages 16,978 Jun 22, 2001 #2 Re: 1996 Johnson 225 Ocean Runner Yes. Fix it now before something worse happens.<br /><br />Good luck!
P Pro23 Recruit Thread starter Joined Jun 14, 2001 Messages 4 Jun 22, 2001 #3 Re: 1996 Johnson 225 Ocean Runner As best I can tell it is the Regulator. Can something else have caused the regulator to go out ?
D Dhadley Supreme Mariner Joined Feb 4, 2001 Messages 16,978 Jun 22, 2001 #4 Re: 1996 Johnson 225 Ocean Runner When you replace the water cooled regulator, go ahead and install the fitting to vent the block to avoid a repeat failure.<br /><br />Good luck!
