1996 Force 75 hp 2 stroke -need owners manual
Mikeymygs
Does anyone know where i can get my hands on an owners manual for a 96 Force 75 HP?
Also I have some problems. But runs fine after getting new 3 new pistons and whoels bored out last year. Problem is now that water barely trickles out the pee hole and sometimes doesnt come out at all when idleing. Just replaced water pump last season so dont know if that is the reason.
Another question I have is the prop. When i bought the boat the prop was damaged and didnt have part number. I came to the conclusion to get 10 3/8 x 14 after dueing research and feel I now need a 10 7/8 x 11 to give more power. My RPm gauge a bit off but i think when working correctly is maxes at 5000 RPM so thats why i feel i need samller pitch to get to 5500 range at top speed. The boat is a 22.5 ft landau pontoon. Thanks!
jerryjerry05
Re: 1996 Force 75 hp 2 stroke -need owners manual
You need an acurate tach to make any kind of decision on a prop.
Any #s at all stamped anywhere on the old prop? J
roscoe
Hi Mike, you need a Clymer Force repair manual, not an owners manual.
The owners manual won't show you anything useful.
Mikeymygs
Jerry,
The tach conenction is loose but when working max was at 4900 rpms. Old prop had no number on it and my neighbor who is knowledgable about boats told me it looked to small anyways. Any ideas? I know ideal rpm max should be around 5500, so what do you think best pitch and diameter should be to acheive this if i need to go up 500 rpm from current prop size.
any ideas on the water coming out of the "pee hole"? From what ive been reading, the force motors have low pressure but im scared to burn out motor since the water is barely trickling out.
thanks!
