Great Wakes Services
Thread starter- Joined
- Jun 27, 2017
- 3
I have a customer with a 90hp V4 with VRO pump setup. The engine begins surging/loss of power at around 3000rpm. I have eliminated several things and I think I have it narrowed down to either the fuel pump or the carbs. When I tested fuel pressure between the pump and carbs it was reading 2psi-10psi. The gauge would drop from 10psi slowly down to 2psi over about 2-3seconds then bounce back to 10psi very rapidly. This seems to indicate an issue with the fuel pump as the service manual says it should never drop below 3psi. I am not sure if the wide range of pressure is normal on these pumps. I am not sure and the part is $600 so just throwing a part at it is not really an option. Any ideas on where to go from here?
Things I have eliminated:
CDI
Temperature Sensors
Fuel supply to the fuel pump
Spark Plugs
Fuel Filter
CDI
Temperature Sensors
Spark Plugs
Fuel Filter
