1996 Evinrude Crankcase Breather Line
senecak19
Can someone tell me where this connects? Mice had a field day with this and I have no idea where it goes. There's no other "dangling" hoses where it should connect. The previous owner gave me a loose piece roughly a foot long so I imagine this it, just no idea where it runs as it too was also eaten. I could have this title all wrong. You can see the nipple to the left of the clamp in the image. If your on the boat looking at the motor it's dead center on the bottom.
Chris1956
Honorary Supreme Mariner
What kind of motor and what HP are you working on. 2 cycle motors do not have breather lines, but they have pulse lines for the fuel pump and can have an extensive fuel recirculation system.
senecak19
It's 1996 Evinrude 225 Vindicator.
It was a crab shoot today but we dropped the boat in the water with a new line from the nipple to the top of air silencer. The boat started perfect. Idled in Neutral like it was ready to go 70mph. I would put it in gear and the motor would immediately go into a "limp mode". As in not over 2500RPM and would not get on plane. I have to believe it's this line and not knowing where it goes. Maybe something else but it idled perfect today.
Chris1956
Your motor probably has an overheat sensor that will kill spark to 1/2 of the motor. 2500 RPM will be about what you would get if that happens. You should hear a buzzer, but that can break. I would suggest a factory service manual for you to use to troubleshoot. The service manual will also show where the vacuum line goes.
Faztbullet
Its possible thats the crankcase vent for the lower bearing. There was several hose routings during these years. You should have a matching nipple on top of engine that comes to this fitting or it will tee off to hose above it with grey fitting. If it has the gray fitting its just a vent and run up side of block.
No sensor to kill spark to 1/2 motor...if overheated.it retards timing so no RPM. Check the timer base to see if rotates when throttle advanced
Chris1956
Does that motor have a shift assist switch as well? That will kill spark to 1/2 the motor as well
Faztbullet
Yes that motor has a shift interrupter and kills spark on 1-3-5 cylinder when shifting into neutral....not going into gear.When you shift from in gear to neutral the shift rod preloads as you trying to force clutch dog to disengage the 5 degree cut on gears, this preload triggers the shift switch which kills that bank of cylindesr and torque is released and unit shifts into neutral.
senecak19
Let me see if I got this right.
- I should test the temp sensor for continuity when cold first. Since it's an easy check.
- How do I "Check the timer base to see if rotates when throttle advanced"?
- Is it possible I did something to the shift switch when servicing the water pump?
I found another post that mentioned the fuel pump going bad but it boggles my mind that it idles and rev's normally in neutral. If the pump had gone bad, wouldn't it sputter in neutral?
Faztbullet
It can run on 3 cylinders and rev up and idle fine, check the spark on all 6 first.....
Pull the cowling off and watch timer under flywheel turn as throttle is advanced...need not be running.
If you knocked it off and reinstalled switch incorrectly yes its possible...easy visual check.
