1996 evinrude 115 tilt trim bleeding down after rebuild
Myomere
Hello! Hope someone can help. I rebuilt my evinrude 115 tilt trim unit after one of the trim pistons sprung a leak. I filled the fluid and it should be full. After some manual lifting of the motor the tilt holds and works up and down until I take the motor all the way down. Then it only comes up as far as the tilt cylinders take it and then if I let go of the button it bleeds down a bit. I manually lift it up and down a few times and it holds again on the tilt. Any ideas? I’m lost. I can let it sit on the tilt and it holds fine until I let it down on the trim cylinders even a little bit. It won’t come back up by itself.
thank you
jakedaawg
If you are lifting it without unscrewing the manual release then it is not full.
cycle several times filling often
seems to me, in my humble experience, that some units that are on a vessel with a more extreme transom angle are tricky to bleed.
Myomere
Thanks for the tip. I have been at this for a while. It seems like something other than air is the issue. I can barely lift it without opening the manual release valve but it then holds u til it hits the trim cylinders and then it seems like air rushes in and I have to bleed it again.
