1996 Evinrude 115 - just turns and turns
jhnnymack1
I just bought a 1996 OMC Sunbird with an Evinrude 115. The engine hasn't been started in 2 years. It only has about 20 hrs on it. I've changed all the fluids and the plugs. When I try and start it it just keeps turning and turning and doesn't start. I've tried holding the key in for an 8 count and then tried starting and the same thing happens. I am at a loss as to why it won't kick over. The only thing I can come up with is that the way I have it on blocks the engine cannot be fully tilted in the down position it is almost straight up and down but not quite. Is there possibly a Mercury switch or something like it that would prevent the engine from starting????<br /><br />Any input on this engine would be greatly appreciated. I bought the boat for my 14yr old son and he is excited to get it running.<br /><br />Thanks so much,<br /><br />John
D
DJ
Guest
Re: 1996 Evinrude 115 - just turns and turns
John,<br /><br />You are missing one of three components:<br /><br />1. Spark.<br /><br />2. Fuel.<br /><br />3. Compression.<br /><br />Take a good look at every connection under the hood. There is one or more that have an in-line fuse in them. Check those. No spark with the blown fuse.
jhnnymack1
Thanks so much Djohns, I never thought of that. Wow I think this board is so cool... thanks for your input I'm sure it will help!!
jhnnymack1
Thanks Specks, I know fuel is getting in but not so sure about the spark, gonna have to check that tomorrow... you guys are great thanks for the advice!!
D
DJ
Guest
John,<br /><br />Just thought of something!!!<br /> :eek: :eek: <br /><br />That engine has a kill switch.<br />Are you sure the engine kill lanyard is on the control box or dash??????
jhnnymack1
Djohns, The kill switch is on the dash. it has the attachment connected to it
