1996 88SPL with Pig-Tail tilt/trim problem
Skiff_Meister
Here is my problem. I have purchased a 1996 Johnson 88 spl without controls. I then went and purchased a control box that has the big red plug. According to my research Johnson changed the Harness in 1996 but that is ok beacuse my motor has the adaptor to accomodate this. (they did change it right?) I got everything hooked up and the motor turns over and all is well but my tilt/trim on my thumb button in my control does not work. I do have a manual button on side of the motor so I did verify that titl/trim do actually work. I have a cable coming out of the control arm on the control box that has a red, a green and a blue wire in it. I am assuming that I need to have a cable that will connect that to my motor? Or does the tilt/trim run over the wiring harness in this set up? Can anybody help? Since 1996 is a transition year and I have the adaptor...I am at a loss. I have pics I can email if it will help get this solved...I can hear the fish calling me. Thanks in advance!
