1996 70hp evinrude idle problem
Walleye Guy92
Motor starts up every time runs great wot. Gets my 16.5 foot Lund up around 30mph. Have problem idling in gear witch can be a pain when docking. Motor idles around 1000rpms in N then drops some when put in gear and will stall if you don't throttle up then she's perfect all the way to wot. Any suggestions on how to fix? Starts right back up every time Just a pain when docking.
Honorary Supreme Mariner
How long have you owned the motor ?-----I can only suggest " no money spent " testing that you need to do.------Report the actual values of a compression test.
Walleye Guy92
Have had the motor for a year. Always seemed to have this problem most of the time it doesn't stall if you throttle up slightly to bring the rpms back around 1000. Don't have a compression tester pulled the plugs top one was a little oily going to change them out. Any suggestions on what to look at before taking into the shop don't want to be down during prime fishing but don't want to cause any damage by keep running like this.
pn
try running some seafoam through it, squirt right into carbs
The black oily sparkplug should be a concern.------Perhaps the top cylinders has problems and is not producing enuff heat to keep the plug clean !------Compression tester is roughly $40. ---Shop time is now $100 / hr at many places.----Your choice.
Walleye Guy92
Never ran seafoam through carbs did run a bottle in the first tank of gas this year. Plug was a little wet not super black excpeted it to be worse with all the trolling I did last year. Will try to pick up a compression tester after work tonight and check tomorrow. Would the motor run that good at all other times if compression was low? Seems like good power all the way through think it tops off around 5800 rpm gets my boat low 30s on a calm day
Walleye Guy92
Picked up a compression tester from harbor freight this morning. Top 2 where right around 100 bottom one was 105. Seems a little low but all pretty close to each other. Test was done with cold engine. Ran it for a minute or two same results not sure if it was fully warmed up or not if that makes any diff. Is this to low? Also idle seems real high with muffs around 1500 rpm according to the dash.
