NC waterboy
Thread starter- Joined
- Apr 6, 2006
- 38
This is my first post not just on iboats but ever,I apoligize for mistakes in advance. My outboard is said to be a 1996 force 40 HP, serial # OE118596.Is the thermostat above the top spark plug when facing the rear of motor? I just purchased the boat 4-5-06 ran the motor and could see no problems ,no indications of over heating ,but when I went to look at the t-stat just as a precaution there is only a spring and a rubber washer in the location I before mentioned. If this should be the t-stat how much damage could be done or what if any benefit would be gained by running this way. Also there is a plug on top of the motor in the same area can I put a temp guage there ? That is if it is not to late.<br />Thank you for your time.
