1996 15hp Gamefisher Engine Help
fishinrocks
Hi I have a 1996 gamefisher 15hp engine and it smokes alot but runs great are there any solutions to this??
CATransplant
Re: 1996 15hp Gamefisher Engine Help
We need more information. The amount of smoke a 2-stroke outboard makes is a matter of interpretation.
What fuel:eek:il ratio are you using? It should be 50:1.
What brand of oil are you using? Synthetics smoke less.
Are you running the outboard in a barrel? The smoke tends to be more visible.
Does it smoke more when you first start it? That's normal.
If the engine seems to be running fine and you're using a 50:1 fuel:eek:il ratio, you're probably making about the normal amount of smoke.
