1996 115 Johnson finally started
jhnnymack1
I bought a 1996 Sunbird with a 1996 115 Johnson on it recently. It sat for two years. I finally got it started and ran it for atleast an hour before taking it out. Today we all went to take it out and it started and ran fine. The problem I am having is that when I throttle up The boat doesn't plane and sits at 3,000 rpms. I thought maybe I the prop was bad, it's a 14 X 17, when I lugged into the marina they said I probably spun the hub. The only replacement they had was a 14 x 19. I tried putting this on but with the same results except that it now ran at 2800 rpms. Any Ideas or suggestions. Is it a prop problem? The prvious owner said it used to run fine, the only difference is that when I picked the boat up from the marine place she had it at they gave me an old aluminum prop, she said she had a new stainless on it. sorry this is so long but you guys have been very helpful in getting this boat going and I just want you all to know the info is much appreciated. Thanks,<br /><br />John
Bear
Re: 1996 115 Johnson finally started
Try pumping the bulb. Not getting enough fuel?<br /><br />Or you have to clean the carbs, check the fuel filter.<br /><br />Check the colour of all spark plugs. What colour are they?<br /><br />(Edit a couple of times)
Walker
It sat for 2 years~! Your carbs need a good cleaning. When you spin a prop the motor accelerates to real high RPMs but the boat doesn't go. generally you can go at idle and a little higher but as soon as you put a load on the prop it starts slipping.
jhnnymack1
Walker, yes it was in storage for two years, my friend the woman I bought it from, she got tired of it had it winerized and stored. I had a problem getting it started but kept taping on the carbs, and squirting ether in it and then it finally started and ran at idles for a long period of time I can rev it up and everything but it seems when I get under way and throttle up it only goes to 3,000 and stays there if I power trim the engine so that it starts coming out of the water the rpms go high. I'm thinking maybe the floats in the carbs are sticking?? is this a possibility?? The engine only has about 25 hrs on it!!! Thought I was getting a great deal!! LOL. Is there a way to check this... You see when I'm idiling I can take the rpms up and down ....I can control it just fine...it's just that when I'm underway it won't go above 3,000 rpms at full throttle.?? I am confused :-(. Thanks for all your help Bear and Walker!!
Walker
Your carbs are most likely gummed up with varnish. Tear them down and soak in carb cleaner over night. Be sure and remove all plastic parts first and blow them out with compressed air after soaking.
