1996 112spl slow to get on plane!
Akduckwacker
OK I have tried everything I can think of. I have 1996 Sprint with 112 spl runs great but when I throttle up to take off I have to send my buddy to front of boat to get up on plane. Now I have a 6 inch jackpate moved up and down with no change. Tried three props. First one being renegade 21 pitch 4 blade, 20 pitch raker three blade and 19 pitch aluminium with no real change other than top speed. Any ideas? Compression checked great, new plugs coils and wires installed, carbs and fuel pump rebuilt, fuel filter and lines replaced. Just can't figure it out need some help what am I overlooking?
Bosunsmate
what was compression? Are you sure your hull isnt waterlogged?
Have you tried a drop test to see if any cylinders arent pulling properly?
Akduckwacker
Compression test 120 on top and 115 on bottom cylinder's. How would I check hull boat did sit in a field for like 5 years.
Bosunsmate
I just know approximately how much one weighs when i try dragging one up a beach, maybe you could get it weighed at a truckstop. If your hull is full of foam then they often get waterlogged
iggyw1
Ensign
I had a problem like this on my last boat. I bought a hyro-foil. It's a set of "wings" that go on your motor gravitation plate to assist in planing. It worked out fine. I was told I would lose some top end speed, and if I did, it was not noticeable to me at all, and the boat planed MUCH easier. The price range is great,, and I bought mine on E-bay for $25.
Akduckwacker
Thanks for all the input. I cut a hole and foam is completely soaked! Going to split in half and fix thanks again!
