1995 tilt/trim problem
99bagger
I HAVE A 150HP FAST STRIKE JOHNSON THE GAUGE IS IN THE UP POSITION THE MOTOR GOES UP/DOWN JUST FINE THE GAUGE IS MY PROBLEM.ANY HELP PLEASE
jakedaawg
Un hook the the trim position sensor. Use an ohm meter and see if you get a varying reading while manually moving it.
Chris1956
Honorary Supreme Mariner
I would check the trim sensor at the motor. If it is good there, chances are the wiring is bad or the gauge is bad.
IMO, a trim gauge is never accurate or reliable. I replaced mine with a water pressure gauge. That is much more useful.
boobie
Disconnect the sender wire on the gauge, turn on the key and ground out the S terminal and see what happens.
