1995 OMC/Ford 5.0 50FAPHUE - Cross Reference to 302 for rebuild kit?
Bnewbold
I'm in need of a rebuild kit for my 50FAPHUE .. and since it's a Ford 302, can I use standard Ford 302 marine rebuild kits (piston heads/rings/bearings/etc)?
Is there any difference between the OMC placarded block than a standard 302 of that same year?
Thanks!
welcome aboard
depends on which heads are on your motor now, and which cam is in there. depending on cam, the firing order changes
I would simply pull your motor and take it to the machine shop first to determine what you need to buy.
