1995 Mariner; Will only run up to 4100 rpm @ WOT
sroy
I own a 1995 17 ft Tracker Nitro with a Mariner 115hp, 4 cylinder; S/N - 0G175997. Before this condition I am about to describe the motor would run about 53 mph (gps) @ 5800 rpm. The prop is a three blade (22).
Recently, something change where I now can only run about 39 mph @4100 rpm.
I have replaced the spark plugs, spark plug wires, fuel filter; no change.
I have performed a compression test and all 4 cylinders measure 134 to 135 psi.
I have measured the resistance of the 4 coils, primary and secondary and they measure in range according to the Mariner Shop Manual. I have also measured the resistance of the Red Stator (Green/White to White/Green) @ 691.4 ohms.
I have measured the DVA voltages from the Red Stator and the Red Stator Adapter
295 @ idle and 320 @ WOT .
I have measured the DVA voltage output of the switch box to the 4 coils.
#1 195 @ idle 204 @ WOT
#2 195 @ idle 240 @ WOT
#3 195 @ idle 200 @ WOT
#4 195 @ idle 240 @ WOT
The kill lead reads 320 @ WOT.
So far, the only unusual reading is the output of the switch box to coils #1 and #3 are reading about 16 % lower than coils #2 and #4.
Would this difference be enough to prevent the motor from reaching 5800 rpm?
flyingscott
Your top RPM for that is 5250. I would check the carb linkages make sure the carbs are opening and nothing is broke a lot of plastic pieces on those.
sroy
Thank you flyingscott for your response. I forgot to disclose that I had verified that all 4 butterfly valves were fully opened at WOT. Does the indication of lower DVA voltages on the primary of coils #1 and #3 verses coils #2 and #4 cause the motor not to reach full rpm? Also, did you find that rpm (5250) from a table or calculation? How is that determined?
flyingscott
The RPM recomendation for your motor is 4750-5250 that is straight from mercury. I owned the 125 version of that I would go to www.cdielectronics.com to find the trouble shooting guide for your ignition. You could have a stator problem in the high speed windings that is a common problem to them. Or it could be the coil windings.
Faztbullet
Well it not the stator as the other cylinders have correct voltage and all the high speed winding is doing is charging the capacitor. I suspect its switchbox SCR's or the internal rectifier has a problem on those two(they are paired in trigger).
